Start using Inspire with our interactive tutorials.
Define contacts, create fasteners, and connect parts with spot welds.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Get started learning how to adjust the view, move parts, run an optimization, and export files.
Prepare and simplify solid geometry, model surfaces, and create PolyNURBS.
View and redefine contacts, and create fasteners including nuts and bolts, screws, and grounded bolts.
Create and use spot welds to connect multiple surface parts.
Run a baseline analysis and analyze a generated shape.
Learn how to run different types of optimizations and compare results.
Define joints and motion contacts, create motors and actuators, run a motion analysis and plot the results.
Learn how to prepare, analyze, and export parts for 3D printing.
Create and modify sketch curves, PolyNURBS, surfaces, and solids.
Create polymesh objects from other types of geometry and results.
Quickly create free-form solid geometry that is smooth and continuous.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
Preapare and run an additive manufacturing simulation, and export a file for 3D printing.
Set up and run a basic porosity or thinning analysis.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
