Set up and run a motion analysis, plot the results, and export the results.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create and modify sketch curves, PolyNURBS, surfaces, and solids.
Create polymesh objects from other types of geometry and results.
Quickly create free-form solid geometry that is smooth and continuous.
Set up your model and run a structural analysis or optimization.
Define motion connections by grounding parts and creating rigid groups and joints.
Apply motors, actuators, springs, and gravity to define the elements for a motion analysis.
Run a motion analysis, plot the results, and extract the results for use in structural (FE) analysis and optimization.
Preapare and run an additive manufacturing simulation, and export a file for 3D printing.
Set up and run a basic porosity or thinning analysis.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
