Coil Spring Dimensions Are Not Realistic
Condition
The coil spring listed in the error message has coils that are penetrating or endpoints that are nearly coincident.
Remedy
  • Decrease the Wire Diameter of the coil spring.
  • Reduce the number of Coils in the coil spring.
  • Use the Move tool or spring endpoint manipulators to separate the endpoints and increase the installed length of the coil spring.
