Massless Part(s) Detected
Condition
The parts listed in the error message have zero mass. If you click the Continue button, they will remain stationary and unconnected.
- Massless Part Detected
- Massless Part(s) Detected in Rigid Group
Remedy
- Click the Fix button to configure off the massless parts, or massless parts inside the rigid group.
- Add mass to the part(s) in the Property Editor, or at least one of the parts inside the rigid group.
- Use the Ground tool to ground the massless parts, or at least one part inside the rigid group.
- Push/Pull 2D geometry into a solid, or specify a non-zero Thickness in the Property Editor.
- Delete the massless parts.
- Put the massless part into a rigid group with other parts that have mass.
