Tutorial: Select, Move, and Scale
Learn how to select, translate, copy, and paste objects, as well as how to use the local and global axes.
In this lesson you will learn about:
- Selecting objects
- Moving, scaling, and rotating
- Copying, copying with history, and paste
- Local and global axes
Selecting Objects
Moving, Scaling, and Rotating
The move tool has three modes. We will focus on the Rotate-Translate and Scale modes.
Rotate-Translate Mode (W Key)
Move/Rotate the Manipulator
Scale Mode (E Key)
Copy, Copy with History, and Paste
- Use Ctrl + C to copy or use Edit - Copy.
- Use Shift + Ctrl + C to copy with history, press Ctrl + V or use Edit - Paste.
