Inspire Studio has some powerful deformation tools that allow you to tweak the shape of a simple primitive object or a complex surface
with a few clicks. In this tutorial, we'll start with a simple cube and turn it into the temple of an eyeglass
frame.
Any object in Inspire Studio can be morphed using cages. Cages can affect either the entire object or a portion of it. With PolyNURBS, you have
additional control of morphing because you can apply various strengths of cages and visualize the effects.
Learn how to create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease
and simplicity of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form
solid geometry that is smooth and continuous.
Learn how to adjust the materials, environment, and properties of objects in the scene to create a photorealistic
image. In addition, learn how to create animations in Inspire Studio.
Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity
of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid
Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts,
and create design iterations on the fly.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined
dimensions. You can also insert a general annotation to label the parts of your model.
Tutorial: Deformation Inspire Studio has some powerful deformation tools that allow you to tweak the shape of a simple primitive object or a complex surface with a few clicks. In this tutorial, we'll start with a simple cube and turn it into the temple of an eyeglass frame.
Tutorial: Morphing
Any object in Inspire Studio can be morphed using cages. Cages can affect either the entire object or a portion of it. With PolyNURBS, you have additional control of morphing because you can apply various strengths of cages and visualize the effects.
