Create Multi-Floor Indoor Database
The WinProp propagation models allow the computation of multiple floors in a building. Creating such a multi-floor database is very easy when all floors have the same layout. In such a case just one floor must be modeled and saved to a file. To add floors, select from the menu and select the file that contains the already modeled floor.
Figure 1. The Move Objects dialog.
Figure 2. Indoor database with four floors.
