Convert Indoor Database from CAD Data File
WallMan includes several import filters for the conversion of indoor building data given in other formats. Database conversion is based on a modular concept.
Figure 1. Converters for indoor building data.
WallMan also offers the possibility to export the currently displayed database as DWG- or DXF-file by using the function DWG/DXF-export from the File menu. Depending on the selected file format and the specified file version in the file save dialog, the database will be exported to a 3D DWG -or DXF–file.
