Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity
of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid
geometry that is smooth and continuous.
Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts,
and create design iterations on the fly.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined
dimensions. You can also insert a general annotation to label the parts of your model.
The Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply
materials, modify the environment, and change the camera position.
Create copies of objects with a parent-child relationship. When you modify the source objects, all of the instances
are updated automatically in the construction history. This is a scene creation tool that is used mainly for rendering.
You can render the entire scene or selected objects in the scene to produce one image file. Renderings can be performed
in a queue. Choose from Render or Render in Darkroom.
Create a Rendering
You can render the entire scene or selected objects in the scene to produce one image file. Renderings can be performed in a queue. Choose from Render or Render in Darkroom.
Manage the Stored Renderings
Show information about, export, and delete a stored rendering. You can also show the alpha channel and continue rendering.
Post-Processing
Manipulate a rendering by modifying the display settings and lighting.
