Select a thin solid and click Extract to extract
the midsurface. Use the microdialog to preview and extract a side face instead.
Select the Midsurface tool.
Select a thin solid.
A preview of the midsurface is shown. The thickness is automatically
calculated and displayed in the microdialog, but cannot be edited.
- Optional:
To extract a side face instead, click the
icon to preview one of the side faces. Click the
icon again to preview the other side face.
Click the preview to confirm and extract the desired face.
The original thin solid is deactivated.
Tip:
- It's generally faster to extract a side rather than the midsurface, and the
results will be the same.
- To restore the original thin solid, open the Midsurface tool and select the
extracted surface.
