Create and edit a 2D sketch curve, and then extrude it to create 3D solid geometry. A sketch curve is any "wire" entity
such as a line, rectangle, circle, or arc.
On the Geometry tab, in the
Modify group, click
the Cut tool.
Optional: By default, the targets are assumed based on where you position the cutting
plane. To select your own targets, click Targets,
and then select one or more parts.
Click Plane, and then click to define the
cutting plane.
As you mouse over the target, a red circular saw appears to indicate where the
cutting plane will be positioned. Hovering over an edge gives a perpendicular
cutting plane, while hovering over a face produces a planar cutting
plane.
Click Cut.
All individual solids are placed into separate parts.
Tip:
To reposition the cut plane using the Move tool,
click .
To align the cut plane to the x-, y-, or z-axis, click .
Keyboard Shortcuts & Mouse Controls
To
Do this
Add to or remove from the selection
Ctrl
Exit tool
Right-click and mouse through the check mark to exit, or double-right-click.
