Supported Roles in the Panopticon Visualization Server
There are four roles supported in the Panopticon Visualization Server:
Role |
Description |
Administrator |
Allowed to perform the following: · view, rename, move, copy, upload, download, interact, and publish/republish workbooks into folders to which the user has permissions to · Add, rename, or remove folders and subfolders and manage users and groups that should be granted or denied access · Import or export workbooks bundle · administer the server which includes: o manage data templates o create global data extracts from connectors o create and manage alerts and specify the email address of the user or group who will receive the alert o view and manage plugin subscriptions o manage caches o specify logging level and view and copy logs o create and manage scheduled tasks o create and manage global parameters o manage workbook themes o view logged in users to the server and log them out o view server settings, set the file logging level, and clear cache |
Viewer |
Allowed to view and analyze fully interactive dashboards. This is the default role assigned to users that cannot be mapped to other roles. |
Designer |
Allowed to perform the following: · view, create, upload, rename, move, copy, merge, download, remove, workbooks, and publish/republish them into folders to which the user has permissions to · Import or export workbooks bundle · Add, rename, or remove folders and subfolders and manage users and groups that should be granted or denied access · create and manage global parameters · create and manage alerts and specify the email address of the user or group who will receive the alert These topics are discussed in the Altair Panopticon Web Authoring Guide. |
Anonymous |
Allowed to view workbooks if authentication.required is set to false. |
Depending on the authentication or user management mechanism used, the role that a user should have is specified and then mapped to a group set in Panopticon.properties.
Property |
Description |
Default Value |
access.administrator.groups |
The role that is mapped to the administrator group. |
admin |
access.default.roles |
The default roles applied to all users of the server. For example, if access.default.roles=DESIGNER,ADMINISTRATOR and a user with a VIEWER role logs on to the server, then the user will simultaneously have a VIEWER, DESIGNER, and ADMINISTRATOR roles. However, if no default roles are wanted, then leave the property blank. NOTE: The roles that can be assigned in this property can only be ADMINISTRATOR, VIEWER, ANONYMOUS, and/or DESIGNER. This property is case sensitive. |
VIEWER |
access.designer.groups |
The role that is mapped to the designer group. |
designer |
access.viewer.groups |
The role that is assigned to the viewer group. |
NOTE |
· Group sets can be added for a role, separated by a comma. · To be able to use all of the features of the Visualization Server, a user is required to have Designer and Administrator roles. · When using the Altair Units licensing, different user roles will check out different numbers of Altair Units.
