Altair® Monarch®
Summary Design
Summary Design allows you to create or edit summaries. You go to this mode from within Summary View.
The Summary Design interface has the following elements:
Element
[ 1 ] Ribbon
Display all the tools you need to edit or define a summary.
Refer to the Summary Design Ribbon Quick Reference.
[ 2 ] Selector
Allows you to search for and/or select a specific summary.
[ 3 ] Summary Design View
Displays the currently-selected summary's properties.
Field Selection Tab
Allows you to define the summary's key, item, and measure fields.
To go to Summary Design, select Summary Design on the Summary View Ribbon.
Creating a summary
  1. Select Add Summary from the Summary Design ribbon. The Summary Window appears, initially displaying the General tab.
  2. Name the summary.
  3. Set general properties.
  4. Set summary fields.
For detailed steps on creating a summary, refer to Creating a Summary.
Selecting a summary
Click the desired summary from the summary selector:
If you have a long list of summaries in the selector, you may opt to search for the desired summary first. To do so, enter a search string into the search box at the top of the summary selector.
