Find
Find entities in the model that contain the search string you enter.Find objects in the scene that contain the search string you enter. The search results are not filtered.
Find Options
| Option | Description |
Navigate to the next or previous entity that contains the search string.Navigate to the next or previous object that contains the search string. |
Find every entity that contains the search string.Find every object that contains the search string. |
Access additional options to control the search:
, and then click one or more of the following
options:
