Inspire Mold is a modern simulation-driven design environment that lets you test, validate, correct, and optimize the design of
injection-molded components.
Find entities in the model that contain the search string you enter.Find objects in the scene that contain the search string you enter. The search results are not filtered.
Configure a model by activating or deactivating parts so they are included or excluded from calculations like mass summaries,
static weight calculations, optimization, etc.
