Tutorial: Immersion Quenching
Set up and run an immersion quenching analysis, then interpret the results.
Open the Tutorial Model
- Open the dumbbell_profile.x_t tutorial model file.
Position the model as shown.
- Set the display units to Metric (mm kg MPa C s).
Orient the Model
Change the Solid Profile
- Click the Quenching ribbon.
Click the Profile icon.
On the model, click the exit surface as shown.
- Enter 1000 mm for Profile Length.
![](../../../images/figures/extrude/New%20Profile.png)
Create an Immersion Quenching Zone
Review the Coolant Material Properties
Run a Quenching Analysis
- Save the model.
Click the Run Analysis icon.
Enter and review the following parameters for the Quenching Analysis:
- Click Run.
