Inspire Extrude creates a PDF report for Steady State analysis. This report explains different aspects of the die, how the material
flows during the extrusion and its influence on extrusion load, temperature changes, flow imbalance, and productivity
with various images.
Use the Show Analysis Results tool to view the results of an analysis in the Analysis Explorer. View and animate results,
add callouts, and compare results from different runs.
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
