Defining VTS Data, Billet Taper, and HTC
Use the Process Data tool to define the variable time step (VTS) data, billet taper, and heat transfer coefficient.
Defining the Variable Time Step Automatically
Transient analysis requires specification of time step data. Metal extrusion is a cyclic process and duration of each cycle is depends on:
  • Ram speed
  • Ram acceleration time
  • Upset billet length
  • Butt length
Inspire Extrude automatically decides the time step data to be used based on the above values. Hence, automatic time step determination is the preferred approach. However, the time step data can be edited and modified using the Process Data tool.
  1. From the Extrusion ribbon, Process Data tools, click VTS.
    The Time Step Data dialog is displayed.
  2. In the Billet Length field, set the length of the upset billet. This value should match the length of the billet created. You can measure and verify this.
  3. In the Butt Length field, set the length of the butt. This value is typically 1-inch. For shorter billets, if actual value is not known, use 1-inch or 10% of the billet – whichever is smaller. For example if the billet length is only 5 inches, specify 0.5 in as the butt length.
  4. In the Ram Speed field, enter the speed at which the punch (also referred to as dummy block or ram stem) moves.
  5. Select either Auto or Manual for the Time Step. Auto is preferred.
Defining the Variable Time Step Manually
The Manual option in the Time Step Data dialog is used to control and change the time step for a transient problem. This allows you to define up to five different time step sizes during the cycle (referred to as zones).
Inspire Extrude automatically estimates the cycle time. You can reduce this cycle time to solve for less than full cycle analysis.
  5. Select Manual for the Time Step.
  6. To reduce the number of cycle times, enter a new value.
  7. Select the number of time zones.
    • For each time zone, you can change only the End Time and Num Of Steps. The rest of the data is automatically computed.
  8. Click OK.
    The following image shows how the time step size in four zones in the table above correspond with the load curve. When the solver is computing the solution, between 0 – 5.0 s, it uses a time step size of 1 second. That is, you will be able to inspect the solution in the post-processor after every second. Then between 5.0 and 15.0 second, it will advance the time in 2 s steps. That is, it will move from 5.0, 7.0, 9.0, 11.0., 13.0, and 15.0. In the same way for the remaining two time zones it will 2.5 and 3.0 s as time step sizes. Inspire Extrude allows you to have from 1 to 5 time zones in defining the time step. It should be noted that the quality of the solution computed is not affected by the size of the step.
Setting Up the Billet Taper
Create the billet before setting up the billet taper.
During extrusion there is heating due to stress work which causes the temperature of the profile to increase during the cycle. This may lead to poor and inconsistent product quality. In order to overcome this, tapered billet heating is used. Inspire Extrude supports the combination of all three types of tapered heating:
  • Axial taper
  • Lateral taper
  • Radial taper
Inspire Extrude enables you to specify this data as used in the extrusion process. This data is relevant and useful only for transient analysis. If you are performing a steady state analysis or bearing optimization analysis, there is no need to specify this data.
  1. From the Extrusion ribbon, Process Data tools, click Billet Taper.
    The Billet Taper Data dialog is displayed.
  2. In the Cycle No column, specify the number cycles to perform the analysis. Inspire Extrude limits the number of cycles to a maximum of 5.
    However, the solver places no limit on this value for simulation. Solvers have a limit that is based on different starter billets and tapers that can vary from cycle to cycle. Taper data used for cycles 1 to 5 can be different from each other; after that, the solver will use the 5th cycle data for rest of the cycles. Computational time for each cycle will be approximately five times the CPU time of steady state analysis, which should be kept in mind when doing a large multi-cycle analysis. In this release, if you would like to do more than 5 cycles, you will have to manually modify the *.hx file and increase this parameter.
  3. Complete the rest of the fields as required.
  4. Click OK.
Billet Taper Examples
Axial Taper
When axial taper is used, temperature of the billet varies along axial direction. This variation can be specified as five zones, each with a linear variation. Billet is hotter on the die end and it is at billet preheat temperature and it is colder (relatively) on the ram end. Images below show the variation and how zones are counted in the solver.
Lateral Taper
When billet is loaded in the container, the bottom portion of the billet comes in contact with the container. Hence, there will be differences in heat transfer rates at the bottom and top portion of the billet and it results in lateral variation of temperature. This gradient becomes important when extruding multiple profiles from a single billet. To compensate for the difference in heat transfer rates, billet may be heated non-uniformly in lateral direction. Later taper data is used to specify this gradient. The image below shows how temperature varies from bottom to top of the billet. In data specification, it is possible make either side (top or bottom) hotter than the other side.
Radial Taper
During extrusion, billet peripheral regions undergo excessive deformation compared to the core region and hence at a higher temperature. To compensate for this, non-uniform radial heating of the billet is used.
Defining Heat Transfer Coefficient
Select faces to specify heat transfer boundary conditions.
  1. From the Extrusion ribbon, Process Data tools, click the HTC tool.
  2. Select a surface to apply the HTC boundary condition.
    Press Ctrl and click surfaces on the model to add or remove boundary conditions by toggling between selected and unselected.
    Hold Ctrl to add multiple faces to the same boundary condition.
  3. Enter the values in the microdialog to assign its heat transfer properties.
