If you've previously run a 3D printing analysis, you can plot the results from the
Analysis Explorer.
Prerequisite: Run a Print3D analysis and view the
results.
Select a run and result type in the Analysis Explorer.
Click the
icon under
Callouts and create at least one callout for each
result type you want to plot.
Click the Plot
icon to view the results plot.
![](../../../images/figures/3Dprint/plot_print_results.png)
Tip:
- Select a callout in the modeling window to highlight it in the
plot.
- Select the callout label in the plot to hide it.
