Sketch Toolbar
You can transfer sketches to a new part, convert reference lines to a sketch, create and move sketch planes, and modify grid settings.
| Sketching Tool | Description | Note |
| New Part |
Create a new part before you start sketching. | Any existing sketch curves will be imprinted onto the current part before the new one is created. |
| Transfer Sketch |
Move your current sketch to a new part. | |
| Convert Lines |
Convert reference lines to sketch curves. | |
| New Plane |
Create a new sketch plane by clicking a face. | Instead of clicking a face, you can select a plane on the sketch plane
selector.![]() |
| Move Plane |
Move the sketch plane. | This opens a version of the Move tool. |
| Options |
Modify your grid and snap settings. | Grid # spacing: Change the default spacing for a grid.
There are five progressive levels of grid spacing. Snaps every # fine grids: Use to adjust snapping behavior for minor grid lines. Snap to grid: Deselect to disable grid snapping entirely. Press Alt to temporarily disable snapping. View normal to plane on create: Automatically rotate your view when a sketch plane is created, so that the sketch plane is normal to the view. |
