Tutorial: Motion Contacts and Force Explorer
Create a motion contact between multiple parts and visualize forces using the Force Explorer.
In this lesson you will learn how to:
  • Create a motion contact between multiple parts
  • Run a motion analysis
  • Visualize forces using the Force Explorer
  • Modify the contact to include friction
  • Individualize a contact
  • Plot motion contact results
  • Save a model with motion results
Open the Altair Inspire Model
  1. Press F7 to open the Demo Browser.
  2. Double-click the M07_GenevaWheel.stmod file in the Motion folder to load it in the modeling window.
  3. Press F2 to open the Model Browser.
  4. Check that the model units in the Preferences are set to MMKS (mm kg N s). You can also change the display units in the Preferences as well.
Run Motion Analysis to View Mechanism Behavior
  1. Click the Motion tab on the ribbon.
  2. Click the Quick Run button on the Analyze Motion tool to see the model in motion, and let the model run to completion.
    The striker part passes right through the Geneva wheel because the contact between the parts has not been defined yet. The slider pulls away from the Geneva wheel after a while.
  3. When the analysis has finished, click the icon on the animation toolbar to play back the motion results.
  4. Right-click in the modeling window, or left-click the Review Motion Results tool to exit review mode.
Create a Motion Contact Between Three Parts
  1. Click the motion Contacts tool.
  2. Click the Cam part.
    The part turns red, and the Parts1 button now has a count of (1) part.
  3. Click the Striker part.
    It turns red and the Parts1 count is incremented to (2).
  4. Click the Parts2 button.
  5. Click the Geneva Wheel Partition 2 part at the periphery of the Geneva wheel assembly.
    The part turns blue, and the Parts2 button now has a count of (1) part.
  6. Click the button. One contact is created as shown in the counter on the ribbon, and you are placed in edit mode.
  7. Right-click and mouse through the check mark to exit, or double-right-click.
Run a Motion Analysis with the Motion Contact Defined
  1. Click the icon in the view controls.
  2. Click the stored view called Start View, then close the Views window.
  3. Click the Quick Run button on the Analyze Motion tool to see the model in motion. Let it run to completion, but do not exit review mode. This time the parts are not passing through each other, and you are seeing 3D contact behavior.
Review Motion Analysis Results Using the Force Explorer
  1. Change the Time on the animation toolbar to 0.30 s by entering a value in the field or by dragging the slider bar.
  2. Click Run on the Motion ribbon, and then click Force Explorer.
    The Force Explorer appears. To undock the Force Explorer, click the title area and drag to the graphics area.
  3. Press F to fit the model in the view.
  4. Press the Play button on the animation toolbar. Notice how the contact forces and torques in the motor and torsion spring develop as the Geneva wheel is indexed around its axis.
  5. In the Force Explorer, toggle some of the checkboxes and entity buttons on/off, and experiment with some of the advanced options.
  6. In the Force Explorer, click the Reset button to revert to the default settings.
  7. Double-right-click in the modeling window to exit review mode, but notice that Force Explorer stays visible-which is what we want.
Edit the Motion Contact to Include Friction
  1. Hold Ctrl while clicking the motion Contacts tool. This puts you in edit mode for Motion Contact 1.
    The contact is selected in the Model Browser, and the red and blue contact pairs are shown.
    Tip: Alternatively, you can enter edit mode while in the motion Contacts tool by selecting a contact in the Model Browser or selecting the motion contacts glyph in the modeling window.
  2. Select Enable friction.
Individualize the Motion Contact
  1. Click the Individualize check box on the guide bar and click the button.
    The counter on the Contacts icon now reports that there are two contacts in the model. This operation separates the single contact between three parts into two contacts between two part pairs. The reason that you would individualize contacts is to plot the motion contact results for each contact pair.
  2. Click the arrow buttons on the guidebar to navigate between each contact pair.
  3. Click the Contacts icon to exit the tool.
Run a Motion Analysis and Animate the Results
  1. Click the Quick Run button on the Analyze Motion tool to see the model in motion, and let the analysis run to completion.
  2. The force vectors at the contact regions now show the tangential component (representing the friction) with straight blue arrows and the normal force component in red.
Plot Motion Contact Results
  1. In the Model Browser, click Motion Contact 2.
  2. Right-click the plot, then click Normal Force.
  3. Right-click the plot again, then click Pop Out.
  4. Right-click the plot, then click Tangential Force.
Save the Model with Motion Results
  1. Select File > Save As and save the model as M07_GenevaWheel_wResults.
  2. To confirm that the saved file contains motion results:
    1. Exit Inspire.
    2. Launch a new session.
    3. Open the file.
    4. Play back the motion results, and plot the results from the last run.
