Connectors
Connectors link points, edges, or faces to each other, and are shown as red lines radiating from a central point. They are generally used to connect two parts together, or to apply a load or support at a distance.
![](../../../images/icons/inspire/icon_connectors.png)
You can also create connectors by clicking the connector icon
located on the microdialogs for the load, support, displacement, or concentrated mass
tools.
Creating Connectors
The Connectors tool automatically creates a point that all of the connectors are connected to. If the connector is deleted, this point will remain in the model.
- Select the Connectors tool.
- Select two points, edges, or faces to connect.
- Optional: Continue selecting features to create additional connector lines.
- Select whether the connector should be Rigid or Flexible in the microdialog.
- Optional: Use the Move tool on the microdialog to reposition the connection point.
- Left-click on empty space to complete the connector and start a new one.
Selecting Connectors
Click a connector once to select it, and double-click to edit it.
Click on a connector in the modeling views to select it. Selected connectors turn orange and the connected locations turn red. All of the connector lines from a particular force, torque, or support are considered a single connector.
![](../../../images/figures/inspire/connectors_selected_1.png)
Double-click on a connector to enter editing mode. When in editing mode, you can add or remove connections to additional geometry features. You can also click to select only those lines that connect the force, torque, or support to a particular geometry feature. Right-click or press Esc to exit editing mode.
![](../../../images/figures/inspire/connectors_selected_2.png)
Invalid Connectors
Connectors are only valid if they connect at least three non-collinear points or two non-collinear edges.
(Collinear points lie on the same line. Non-collinear points do not.) For example:
![](../../../images/figures/inspire/connectors_example3.png)
Example 1: This connector is not valid, because it connects to a single point on the model.
![](../../../images/figures/inspire/connectors_example4.png)
Example 2: This connector is not valid, because it connects to only two points on a single collinear edge.
![](../../../images/figures/inspire/connectors_example2.png)
Example 3: This connector is valid, because it connects to three points on two non-collinear edges.
![](../../../images/figures/inspire/connectors_example1.png)
Example 4: This connector is valid, because it connects to a single non-collinear edge (the circle shown in red).
