Load Results in the Analysis Explorer
Use the Analysis Explorer to view the results of an analysis.
Click the Show Analysis Results tool on the
Analyze icon to open the Analysis Explorer.
- Select the Run you want to view.
- Select a Load Case.
- Select a Result Type. The result is displayed in the modeling window.
- Use the additional options to animate the result, change what is shown in the modeling view, create callouts, and compare results.
- Right-click or press Esc to close the Analysis Explorer and return to the original part.
Analysis Explorer Options
The Analysis Explorer includes the following options.
Run
![](../../../images/inspire/analysis_explorer_run.png)
To delete a run from the Analysis Explorer, right-click the run name to select Delete Run.
Load Case
![](../../../images/inspire/analysis_explorer_load_case.png)
The Result Envelope is created when you have two or more static load cases. It shows the maximum value for each result type across all load cases.
Result Types
![](../../../images/inspire/analysis_explorer_result_types.png)
Modes
All physical objects have frequencies at which they vibrate that are called normal modes. If you chose to run a normal modes analysis in the Run Analysis window, the modes will be listed here when you select Normal Modes for the Load Case. Click on a mode to view the displacement for that mode.
![](../../../images/inspire/analysis_explorer_modes.png)
Bucking Load Factors
![](../../../images/inspire/analysis_explorer_bucklingloadfactors.png)
Results Slider
![](../../../images/inspire/analysis_explorer_results_slider.png)
- To change the upper or lower bound for the results slider, click on the
bound and enter a new value. Click the reset
button to restore the default values.
- To filter the results so that areas on the model with results greater than a
specified value are masked, click and drag the arrow on the results slider.
To mask areas with results less than the specified value, click
and select Flip Mask. Select the arrow to enter a specific value.
- To change the legend color for the result type, click the
icon next to the results slider and select Legend Colors.
- To apply the min/max values for the current result type to all load cases,
click the
icon next to the results slider and select Apply current min/max to all load cases.
- To reset the min/max values for the current result types for all load cases,
click the
icon next to the results slider and select Reset min/max of all load cases
Compare Results
Click the Compare Results button at the bottom of the Analysis Explorer to view a table that allows you to compare analysis runs.
![](../../../images/inspire/compare_results_button.png)
Results are compared in a table format. Additional columns can be added to show additional result types and parameters from the Run Analysis window. The red-blue color bands correspond to the legend in the Analysis Explorer; the width of the band indicates the magnitude of the result. Changes to the upper and lower bound in the Analysis Explorer are automatically reflected in the Compare Analysis Results table.
![](../../../images/inspire/compare_analysys_results.png)
- Select a row to display the results for that run and load case.
- Double-click a cell in the table to show that result in the modeling window
- Click the chevron next to the table title to select a different result type or a callout.
- Click the chevron on a column header to filter results.
- Click a column header to sort the column
- Right-click a column header to change what result types, run parameters, or callouts are shown in the table.
- Click the top left corner of the table to copy the contents of all cells. This can then be pasted into Excel.
Show/Hide Elements
When the Analysis Explorer is active, an additional Show/Hide Elementsicon appears under the view controls in the lower left corner of the modeling window
Animation Options
The animation options on the Analysis Explorer allow you to start and stop the animation and adjust basic settings.
Option | Description | |
Play/Stop Animation | ![]() |
Animate the selected result. |
Animation Speed | ![]() |
Change the speed of the animation. |
Scale by | ![]() |
Change the scale of the animation. Generally the scale of a displacement is too small to see clearly, so auto scaling is enabled by default. This option is only available for structural results, not motion results. |
Show Options
Determine what is made visible in the modeling window when viewing analysis results. You can show or hide the initial shape, loads and supports, deformation, and/or contours.
Option | Description | Note | |
Show/Hide Initial Shape | ![]() |
Show/hide the initial shape as a reference. | |
Show/Hide All Loads and Supports | ![]() |
Show/hide loads and supports. You can also show only the current loads and supports. | |
Show/Hide Deformed State | ![]() |
Show/hide the deformed shape as a reference. | |
Show/Hide Contours | ![]() |
Show/hide contours. | |
Options | ![]() |
Show/Hide Elements | ![]() ![]() |
Show/hide the element edges. | This icon also appears under the view controls in the lower left of the modeling window. |
Callout Options
Add visual callouts to show points of interest on your analysis results.
Callout Icon | Description | Note |
Create, Show, and Hide Callouts![]() |
Select to create callouts; select to show and hide callouts. |
List Callouts![]() |
Display in a table all of the callouts that have been created, with
the result types and values. Each callout is specific to the selected
run and load case.![]() |
Min/Max Callouts![]() |
Create a callout showing where the minimum/maximum value occurs for
the selected result type. Note: When factor of safety is selected, the
minimum value is shown.
Plot | Display time history plots for callouts defined for structural analysis. Changes made to the Result Types option are synchronized with the setting on the Analysis Explorer. Using this option allows you to put multiple plots of mixed types on a single page. | This option is only available for motion part analysis results. |
Dynamic Callouts![]() |
Display the results of various result types in existing callouts.
Note: If you enable the Compare Results feature in a callout, the
callout becomes static.
After creating a callout for a particular result type, click the
