Force Vectors Are Unavailable
Condition
Entity buttons are missing on the Force Explorer.
![](../../../images/inspire/force_explorer_entity_buttons.png)
Cause
The buttons are missing because either the Plots option has been set to None, or you are not using Global reference frame for plotting.
Remedy 1: Plots Are Turned Off
- Set Plots to All in the Advanced section of the Run Motion Analysis Settings.
- Rerun the analysis.
Remedy 2: Plots Are Not Global
- Set Plots to Global in the Advanced section of the Run Motion Analysis Settings.
