Motor/Actuator Is Ignored During Statics Analysis
Condition
The motor/actuator will not behave as expected, because the velocity and acceleration are set to zero for a statics analysis.
- Speed Motor Is Ignored During Statics Analysis
- Velocity Actuator Is Ignored During Statics Analysis
- Acceleration Motor Is Ignored During Statics Analysis
- Acceleration Actuator Is Ignored During Statics Analysis
Remedy
- Change the motor type to Angle, or the actuator type to Displacement.
- Run a transient instead of statics analysis by changing the Run Motion Analysis settings.
- If using a speed motor or velocity actuator, disable the controller to lock the motor during a statics analysis.
