If you've previously run a motion analysis, use the Review Motion Results tool to open the Animation Toolbar and animate
the mechanism. You can also pick an object to plot.
If you've previously run a motion analysis, use the Review Motion Results tool on the Analyze icon to plot the results. You can export the plot in .csv format. For parts, you can also export loads.
Use the Analyze Motion tool to run and review the results of a motion
analysis.
Analyze Motion icon
Run Motion Analysis
Use the Quick Run and Run Settings tools to define and run a motion analysis.
If you've previously run a motion analysis, use the Review Motion Results tool to open the Animation Toolbar and animate the mechanism. You can also pick an object to plot.
Plot Motion Results
