Starter Subroutine LECSEN_USRn
This subroutine read the user’s sensor input data. The number of cards and their formats are free.
Arguments
The argument list of LECSEN_USRn and its individual arguments and descriptions are:
C-------------------------------------------------------------------------
     SUBROUTINE LECSEN_USRn(IIN, IOUT)
Argument Format Description
IIN Integer read only scalar Input file unit (Starter input file) on which the data are read.
IOUT Integer read only scalar Output file unit (Starter output file).
Storage Functions for Sensor Parameters (Starter Only)
To store data in a sensor’s parameters buffers, use:
  • integer ierr = SET_U_SENS_IPAR(integer isens, integer sens_index, integer var)
  • integer ierr = SET_U_SENS_FPAR(integer isens, integer sens_index, float var
These functions store an integer or float variable in respective buffers, at a position indicated by sens_index, which is independent in each buffer. The length of sensor parameter buffers is limited to 12 integer variables and 20 float variables.
