User Sensor Example
A sensor stores a maximum von Mises stress value (F).
CR =1 sensor parameter (read in Starter by sensor user’s subroutine LECSEN_USRm)
F = 1 sensor variable (written to sensor buffer by material user’s subroutine SIGESPnn)
Sensor is activated in F > CR. The activation time of the sensor is displayed.
![](../../../images/solvers/radioss_user_code_4_node_shell_elements.png)
Figure 1. Loading Case: Imposed Velocities Applied on Two Nodes
Example Demo File
<install_directory>/hwsolvers/demos/radioss/User_Subroutines/5_user_sensors/
