Run Options
- The OptiStruct Script.
- The Altair Compute Console
- HyperMesh
For more information on Altair Compute Console, navigate to from the Altair Compute Console GUI.
Option | Argument | Description | Supported Platform | |
-acf |
N/A | Option to specify that the input file is an ACF file for a multibody dynamics solution sequence. | All Platforms | |
-aif |
N/A | An internal option generated automatically when a job is
run from the Compute Console (ACC) (for OptiStruct runs)
with Use Solver Control (-screen manual option entry) turned
ON. -aif is added to the command line to allow
Abort/Stop functions. The -aif start option is an internal option and
is not part of the Compute Console (ACC) Options Selector and can be ignored. |
All Platforms | |
-altver |
Alternate Version | Controls the alternate version of the OptiStruct executable to be used. The OptiStruct executables are available in the following folder
within both Linux and Windows executables.
Note:
All Platforms | |
-amls |
YES, NO | Invokes the external AMLS eigenvalue solver.
The AMLS_EXE environment variable needs to point to the AMLS
executable for this setting to work.Overrides the PARAM, AMLS setting in the input file. (Example:
Linux | |
-amlsncpu |
Integer > 1 | Defines the number of CPUs to be used by the external AMLS
eigenvalue solver. OptiStruct and AMLS can be run with different allocations of processors. For example, OptiStruct can be run with 1 processor and AMLS with 4 processors in the same run. Only valid with Overrides the PARAM, AMLSNCPU setting in the input file. Default = 1 (Example: |
Linux | |
-amlsmem |
Memory in GB <Real> |
Defines the amount of memory in Gigabytes to
be used by the external AMLS eigenvalue solver. This run option is only supported for
AMLS versions 5 and later. Note:
Linux | |
-amses |
YES/BOTH | Invokes the AMSES eigenvalue solver.
Note: When the executable is run directly (not recommended), then
-amses (without any other arguments) will activate AMSES for the
structural model. This is not possible when running using the script or the Compute
Console (ACC). |
All Platforms | |
-analysis |
N/A | Submit an analysis run even if optimization cards are
present in the model. This option will still read and check the optimization data and
the job will be terminated if any errors exist. (see -optskip below,
to submit the analysis run without performing the check on optimization data).The
Cannot be
used with (Example:
If an OptiStruct optimization model has DOPTPRM, DESMAX, 0, the number of license units checked out is the same as the checkout for an OptiStruct analysis job. |
All Platforms | |
-asp |
N/A | When INCLUDE files are used, this
option strips the path from all filenames in the input file, leaving only a root name
with extension. This forces all input and output files to be located inside the same
folder (or subfolders defined using the -incpath option).When both
-asp and -incpath run options are used, the path
defined with -incpath is also stripped from all but the actual
folder’s name and is treated relative to the run folder.Note: This option is useful
only when automated scripts are used to submit jobs to multi-user (local or
remote) machines.
All Platforms | |
-buildinfo |
N/A | Displays build information for selected solver executables. | OptiStruct | |
-check |
N/A | Submit a check job through the command line. The memory needed is automatically allocated. Cannot be used with
(Example: |
All Platforms | |
-checkel |
YES, NO,
FULL
Note: An argument for
-checkel is optional. If an
argument is not specified, the default argument (YES) is
assigned. |
(Example: (Example: |
All Platforms | |
-compose |
{compose_installation_path} | This option specifies the location of the Compose installation directory. This run option must be used when Altair Compose is invoked during an OptiStruct run, in case of an external response (DRESP3). (Example: For further information, refer to External Responses using solidThinking Compose. |
All Platforms | |
-compress |
N/A | Submits a compression run. Reduces out matching material and property definitions. Property definitions referencing deleted material definitions are updated with the retained matching material definition (reduction of property definition occurs after this process). Element definitions referencing deleted property definitions are updated with the retained matching property definition. The resulting Bulk Data file will be written to a file named <filename>.echo. It is assumed that there is no optimization, nonlinear or thermal-material data in the Bulk Data. If such data are present in the input file, the resulting file (<filename>.echo) may not be valid. The
(Example: Refer to Compression Run for more information. |
All Platforms | |
-core |
in, out, min |
The solver assigns the appropriate memory required. If there is not enough memory
available, OptiStruct will error out. Overwrites the
(Example: |
All Platforms | |
-cores |
auto, N | Total number of cores to be used for an MPI job. For
both arguments (auto and N),
np =
2 will be enforced.
Note: Number of
cores = np *
nt .Examples:
All platforms | |
-cpu ,
-proc , -nproc , -ncpu ,
-nt or -nthread |
Number of cores | Number of cores to be used for SMP solution. (Example:
All Platforms | |
-ddm |
N/A | Runs MPI-based Hybrid Shared/Distributed Memory Parallelization (SPMD) in Domain Decomposition Mode. DDM
is activated by default when any MPI run is requested by specifying
Not all platforms are supported. Refer to Hybrid Shared/Distributed Memory Parallelization (SPMD) for the list of supported platforms. | |
-ddmngrps |
Number of MPI process groups < Integer ≥1, MAX, MIN, AUTO, or -1> |
Note: The
-ddmngrps run option is also available for this feature. If
both are defined simultaneously, then
PARAM,DDMNGRPS is overwritten by the options
defined on -ddmngrps run option.
Refer to DDM Level 1 – Task-based parallelization in Domain Decomposition Method (DDM). |
All Platforms | |
-delay |
Number of seconds | Delays the start of an OptiStruct run for the specified number of seconds. This
functionality does not use licenses, computer memory or CPU before the start of the
run (the delay expires). This option may be used to wait for any computing resources
which are currently usable but are not yet freed by the previous run. If the
previous run crashed, the license may still be locked by the license server
depending on the timeout value, or the memory may still be reserved by the Operating
System.
Note:
All Platforms | |
-dir |
N/A | The run location is changed to the directory where the input file is located before the run is initiated. | All Platforms | |
-ffrs |
YES/NO | Invokes the external FastFRS (Fast Frequency Response
Solver) solver. The FASTFRS_EXE environment variable should point to
the FastFRS executable for this setting to work.Overrides the PARAM,FFRS setting in the input file. (Example: |
Linux | |
-ffrsncpu |
1, 2, or 4 | Defines the number of CPUs to be used by the external
FastFRS eigenvalue solver. This parameter will set the environment variable
OMP_NUM_THREADS .The default value is the current value of
OMP_NUM_THREADS . Note: This value can be set by the command line
arguments
–nproc or –ncpu .OptiStruct and FastFRS can be run with different allocations of processors. For example, OptiStruct can be run with 1 processor and FastFRS with 4 processors in the same run. Valid only when the
Overrides the PARAM, FFRSNCPU setting in the input file. Default: Number of processors used by OptiStruct. (Example: |
Linux | |
-ffrsmem |
be used by the external FastFRS eigenvalue solver. This run option is only supported
for FastFRS versions 2 and later. Note:
Linux | |
-filemap |
<filename | This option is useful internally, during the submission of
a job to a remote server or queuing system. Usually, during submission of the job to a remote server or queuing system, filenames specified in the input deck cannot be used (e.g. when they contain Windows-specific names, and the remote server is using Linux). This option is also used when the input file consists of INCLUDE files with identical names (in different locations). The contents of <filename> specify a dictionary of filenames (a list of filename pairs, one filename per line). The order of pairs in the file is irrelevant. Before opening any input file OptiStruct will check this map, and instead of opening the file as defined by the input deck, it will open the corresponding filename in the dictionary. Usage of When The contents of <filename> are split in two groups. The first group refers to the names used on include statements. For
these entries, the first name in a pair must be a single asterisk and a number (n).
This indicates a map to the nth file listed by
The second group is the list of other names. The first name is compared verbatim to the content of the one used on ASSIGN, RESTART, and similar cards). Example (notice that spaces
at the start of each line are optional, added here for
readability):
The use of this filemap will result in substituting /scratch/file_155.fem for the second INCLUDE file and file /scratch/folder/restart.txt will be substituted instead of any file referenced as 'restart.sh' with no path (presumably on the RESTART card). The comparison is always case sensitive,
even on Windows hosts which disregard the case in filenames.
useful only when automated scripts are used to submit jobs to multi-user (local or
remote) machines.
All Platforms | |
-fixlen |
RAM (In MB, by default) See Comment 5 |
Disables dynamic memory allocation OptiStruct will allocate the given amount of memory and use it
throughout the run. If this memory is not available, or if the allocated amount is
not sufficient for the solution process, OptiStruct will
terminate with an error.
CAUTION:
To avoid over specifying the memory when using this option, it is
suggested first to run OptiStruct with the
This option allows, on certain platforms, to avoid memory fragmentation and allocate more memory than is possible with dynamic memory allocation. Overwritten by (Example: |
All Platforms | |
-gpu |
N/A | Activates GPU computing. | All Platforms | |
-gpuid |
N | N: Integer, Optional, Selects the GPU card.
Default = 1 |
All Platforms | |
-h |
N/A | Displays script usage. | All Platforms | |
-hostfile |
<filename> | This option allows usage of multiple hosts (machines) for
a MPI run, by specifying the list of hosts in a separate file
(<filename>) .When Examples: Let hostfile.txt be the file that contains the list of hosts, with the following contents.
1:
-np is specified.
In
this example, 4 MPI processes will be used for each host ( Example 2:
host1
and host2 ). |
All Platforms | |
-hosts |
List of host names (comma separated) | This option allows usage of multiple hosts (machines) for
a MPI run, by directly specifying the hosts as argument to the run option. When this
option is used, the number of MPI processes ( (Example: |
All Platforms | |
-incpath |
<path> | The incpath option modifies the search
for files defined in the input deck $ INCLUDE <filename> . All folders defined on this option are used to search for any include file defined in the input deck. If the additional option If this option is used, then incpath from .cfg file has no effect. When <filename> on incpath is a relative path, it is always relative to the run folder (the location where the job is executed). The
Example: |
All Platforms | |
-inventory |
N/A | This option forces OptiStruct
into a short run, which produces a special file named
<filename>.flst (.flst file). This file
contains a list of all input files needed for a run and their actual
locations. Example: *.flst file uses XML
format.
In
this file, the OptiStruct input files are referenced by
In the presence of In part-instance
mode, it is expected that the same file may be read multiple times, and this will
result in the same line repeated multiple times. This is consistent with the
.flst file created with |
All Platforms | |
-len |
Preferred upper bound on dynamic memory allocation. When
different algorithms can be chosen, the solver will try to use the fastest algorithm
which can run within the specified amount of memory. If no such algorithm is
available, the algorithm with minimum memory requirement will be used. For example,
the sparse linear solver, which can run in-core, out-of-core or min-core will be
selected. The Default = 8000 MB. (Example: Best
practices for
–len specification: For proper memory allocation
while using –len in an OptiStruct run,
avoid using the exact reported memory estimate value (for example, Using Check). The
–len value should be provided based on the actual memory of the
system. This would be the recommended memory limit to run the job, it may not
necessarily represent the memory utilized by the job or the actual memory limit.
This way, the job is more likely to run with the best possible performance. If the
same system is shared by multiple jobs, the memory allocation should follow the same
procedure as above; except, that the individual maximum memory should be used in
place of the total system memory. If a job runs out-of-core instead of in-core (it
exceeded the memory allocation) it will still run very efficiently. However, make
sure that the job does not exceed the actual memory of the system itself as this
will slow the run down by a large factor. The recommended method to deal with this
is to specify –maxlen as the actual memory of the system to limit
the maximum memory that can be used on the system.Note: If a value
greater than 16 GB is specified, the internal long (64-bit) integer sparse direct
solver is activated automatically.
All Platforms | |
-lic |
FEA, OPT |
The solver checks out a license of the specified type before reading the input data. Once the input data is read, the solver verifies that the requested license is of the correct type. If this is not the case, OptiStruct will terminate with an error. No default (Example: |
All Platforms | |
-licwait |
Hours to wait for a license to become available Note: An argument for
–licwait is optional. If the
argument is not specified, the default argument (12) is assigned. |
If -licwait is present and
sufficient HyperWorks Units are not available, OptiStruct will wait for up to the number of hours specified
(default=12) for licenses to become available and then will start to run. The maximum
wait period that can be specified to wait is 168 hours (a week). OptiStruct will check for available HyperWorks Units every two minutes.Note: If sufficient units are
not available initially, OptiStruct will wait for two
minutes before checking again. Therefore, this process does not guarantee any place
in queue for license checkout. If sufficient units are checked back in to the
license server inside the two-minute window, but another process requests the HWU’s
before OptiStruct checks again, the units will be taken
up by the other process, and OptiStruct will continue to
wait until enough HWU’s are available at the time it checks for their availability
(every two minutes).
All Platforms | |
-localfilesonly |
N/A | Similar to -asp , but it
affects only the INCLUDE paths. |
All Platforms | |
-manual |
N/A | Launches the online OptiStruct User Guide. | All Platforms | |
-maxlen |
Hard limit on the upper bound of dynamic
memory allocation. OptiStruct will not exceed this limit. No default (Example: |
All Platforms | |
-minlen |
Hard limit on the lower bound of dynamic
memory allocation. This is the minimum amount of memory allocated in the dynamic memory allocation process and OptiStruct will not go below this limit. Default = 10% of (Example:
All Platforms | |
-mmo |
N/A | The –mmo option
can be used to run multiple optimization models in a single run. |
-monitor |
N/A | Monitor convergence from an optimization or nonlinear run. Equivalent to SCREEN, LOG in the input deck. | All Platforms | |
-mpi |
i (Intel
MPI), pl (IBM Platform-MPI (formerly HP-MPI)), ms (MS-MPI), pl8 (for
versions 8 and newer of IBM Platform-MPI)
–mpi is optional. If an argument is not specified, Intel MPI is
used by default. |
Specify the Message Passing
Interface (MPI) type for use MPI-based SPMD runs on supported platforms. Specify the Message Passing Interface (MPI) type for use MPI-based SPMD runs on supported platforms. |
-mpiargs |
(arguments for
mpirun > |
This run option can be used in MPI-based parallelization
runs to specify additional arguments for mpirun .Note: This option is valid for an MPI run only. (Example:
optistruct infile.fem
–mpi i –np 4 –mpiargs “<args_for_mpirun>” ). |
-mpipath |
path | Specify the directory containing HP-MPI’s
mpirun executable.Note: This option is useful if MPI
environments from multiple MPI vendors are installed on the system. Valid for an MPI
run only.
(Example: |
-ncpu |
Number of cores | Same as -cpu |
All Platforms | |
-ngpu |
Number of GPUs | N: Integer, Identifies the number of GPU cards to be used
for the solution. Default = 1. Maximum = 8 |
All Platforms | |
-nlrestart |
Subcase ID | Restart an explicit dynamic solution sequence from
specified Subcase ID. If Subcase ID is not specified, it will restart from the first
explicit dynamic subcase ending with error in previous run.
Note: The
explicit dynamic solution sequence is a series of explicit dynamic subcases
(ANALYSIS=EXPDYN) linked by
CNTNLSUB.
All Platforms | |
-np |
Total number of MPI processes for MPI runs | Total number of MPI processes to be used in MPI runs in
SPMD. Even if multiple nodes are used in a cluster MPI run, -np still
indicates the total number of MPI process for the entire run across multiple cluster
nodes.Note: If
-nt is not defined, then it is recommended that
-np should be set lower than the total number of available cores.
If -nt is specified in addition to -np , then the
it is recommended that -np *-nt should not exceed
the total number of available cores. For more detailed information, refer to the
Hybrid Shared/Distributed Memory Parallelization (SPMD).(Example:
-nproc |
-cpu |
All Platforms | |
-nt |
-cpu |
All Platforms | |
-nthread |
-cpu |
All Platforms | |
-optskip |
N/A | Submit an analysis run without performing
check on optimization data (skip reading all optimization related cards). Cannot be
used with (Example:
All Platforms | |
-out |
N/A | Echos the output file to the screen. This takes precedence
over the SCREEN I/O Options Entry. (Example: |
All Platforms | |
-outfile |
Prefix for output filenames | Option to direct the output files to a directory different
from the one in which the input file exists. If such a directory does not exist, the
last part of the path is assumed to be the prefix of the output files. This takes
precedence over the OUTFILE I/O Options Entry. (Example:
All Platforms | |
-proc |
-cpu |
All Platforms | |
-radopt |
Run Radioss optimization in OptiStruct | Option to run Radioss
optimization in OptiStruct. A Radioss optimization file <name>.radopt
should be input to OptiStruct and the optional
–radopt run option may be specified to request an optimization run
for a Radioss input deck.Note: The Radioss Starter and input files supporting the optimization
input should be available in the same directory as the
<name>.radopt file.
Refer to Design Optimization in the User Guide for more information. |
All Platforms | |
-ramdisk |
Size of virtual disk (In MB, by default)
See Comment 5 |
Option to specify area in RAM allocated to store
information which otherwise would be stored in scratch files on the hard drive. The upper limit of RAMDISK for Compute Console (ACC) or OptiStruct script is 10,000,000 (10 TB). (Example:
For a more detailed description, see the RAMDISK setting on SYSSETTING I/O Options Entry. |
All Platforms | |
-reanal |
Density threshold | This option can only be used in combination
with -restart . Inclusion of this option on a restart run will cause the last iteration to be reanalyzed without penalization. If the "density threshold" given is less than the value of MINDENS (default = 0.01) used in the optimization, all elements will be assigned the densities they had during the final iteration of the optimization. As there is no penalization, stiffness will now be proportional to density. If the "density threshold" given is greater than the value of MINDENS, those elements whose density is less than the given value will have density equal to MINDENS, all others will have a density of 1.0. Example:
All Platforms | |
-restart |
filename.sh | Specify a restart run. If no argument is
provided, OptiStruct will look for the restart file, which
will have the same root as the input file with the extension .sh.
If you enter an argument on PC, you will need to provide the full path to the restart
file including the file name. Cannot be used with (Example:
(Example: |
All Platforms | |
-rnp |
Number of processors | Number of processors to be used in Hybrid Shared/Distributed Memory Parallelization (SPMD) for EXPDYN
analysis. (Example: |
All Platforms | |
-rnt |
Number of cores | Number of cores to be used for OptiStruct SMP for EXPDYN analysis.
(Example: |
All Platforms | |
-rsf |
Safety factor | Specify a safety factor over the limit of
allocated memory. Not applicable when (Example: (Example: (Example: |
All Platforms | |
-savelog |
N/A | Saves the screen output to a permanent file named <filename>.log. This can be useful during debugging, as OptiStruct prints some messages only to screen. The SCREEN I/O Options Entry is required in conjunction for maximum information to be printed to the .log file. | All Platforms | |
-scr or
-tmpdir |
path, filesize=n, slow=1 | Option to choose directories in which the scratch files
are to be written. filesize=n and slow=1 arguments
are optional. Multiple arguments may be separated by a comma.
(Example: Multiple scratch directories
may be defined through repeated instances of (Example: This
overwrites the environment variable For a more detailed description, see the TMPDIR I/O Options Entry. |
All Platforms | |
-scrfmode |
basic, buffered, unbuffer, smbuffer, stripe, mixfcio | Option to select different mode of storing scratch files
for linear solver (especially for out-of-core and minimum-core solution modes).
Multiple arguments may be comma separated. (Example: For a description of the arguments, see the SCRFMODE setting on SYSSETTING I/O Options Entry. |
All Platforms | |
-testmpi |
N/A | Check if MPI is configured properly and if the
SPMD version of the OptiStruct executables is available
for this system. (Example: |
All Platforms | |
-sp |
N/A | Option to select the Single Precision executable for the run. This allows you to select the 64 bit Integer 32 bit Floating Point Build for either the SMP or MPI runs. | All Platforms | |
-v |
Version | Controls the version of the OptiStruct executable to be used. The OptiStruct executables are available in the following folder
Note: By default, the highest version from within the available executables
will be used if the
-v option is not defined. |
-version |
N/A | Checks version and build time information from OptiStruct. | All Platforms | |
-xml |
N/A | Option to specify that the input file is an XML file for a multibody dynamics solution sequence. | All Platforms |
- Any arguments containing spaces or special
characters must be quoted in {}, for example:
-mpipath
{C:\Program Files\MPI}. File paths on Windows may use backward "\" or forward slash "/" but must be within quotes when using a backslash "\". - Currently, the solver executable (OptiStruct) does not have a specific limit on the number of
processors/cores assigned to the SMP part of the run
-nt
/-nthread
). - The above arguments are processed by solver script(s) and not by the actual executable. If you are developing internal scripts which use the executable directly, you may get specific information about command line arguments that are accepted by the executable by looking at the content of the .stat file, where these arguments are listed for each run.
- The order of the above options is arbitrary. However, options for
which arguments are optional should not be followed immediately by the
INPUT_FILE_NAME
argument. - In case of memory related options
-len
,-fixlen
,-minlen
,-maxlen
and-ramdisk
), the default unit of memory is MB. However, suffixes M/m and G/g can be used to represent memory in MB and GB, respectively.Examples:
-minlen
2G or-minlen
2000M
