OS-E: 0180 3-Point Bending using RBODY
Demonstrates RBODY which is used in this nonlinear large displacement implicit analysis involving contacts using OptiStruct.
Figure 1. FE-Model with Loadcases and Loadstep
Model Description
This model consists of a steel beam resting on two steel supports and crushed from the middle using another steel cylinder. Sliding contacts are defined between the cylinders and the steel beams. The cylinders are defined as RBODY and the centroid nodes are defined as the reference node, on which the load and boundary conditions can be applied. A load of 500N is applied on the centroid node (reference node) of the big cylinder, the big cylinder can move only in the x direction and the two small cylinders are constrained in all the DOFs. Here a nonlinear implicit analysis is run.
The shell element properties are:
FE Model
Steel Beam and Cylinder
First order shell elements
The MAT1 material properties are:
Young's Modulus
210 GPa
Poisson's Ratio
0.3
Initial Density
7.9 x 10-6 kg/mm3
Results
Figure 2 shows the deformed shape of the steel beam after it is pushed down by the cylinder.
Figure 2. Deformed Shape of Steel Beam
Figure 3 shows the stresses in the rigid bodies after the load is applied.
Figure 3. Stress on the Rigid Body as Zero
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/3Point_Bending_RBODY.fem
