OS-E: 0140 Pretension Analysis of Piston
Convert an Abaqus model to OptiStruct using HyperMesh and SimLab.
Figure 1. FE Model
Model Description
Nonlinear Static Analysis with large displacement is conducted on this piston assembly, where pretension force is applied on both the sides of the piston bolts (Figure 1).
FE Model
Element Types
CTETRA
The linear material properties are:
MAT1
Young’s Modulus
2.1E5 MPA
Poisson's Ratio
0.3
Density
7.9E-9
Results
Using the conversion tool, you will be able to convert this Abaqus FE model successfully and then the displacements and stress results should match with Abaqus closely (Figure 2).
Figure 2. Stress and Displacement Contour in OptiStruct
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/PISTON_PRETENSION.inp
