OS-E: 0160 Nonlinear Static Analysis of Snap Fit Assembly Using Continuous Sliding
Demonstrates the effect of continuous sliding in Nonlinear Static (large displacement) Analysis.
Figure 1. FE Model
Model Description
- FE Model
- Elements Types
- CTETRA
- MAT1
- Young’s Modulus
- 5E3 MPa
- Poisson's Ratio
- 0.3
- Density
- 1.1E-9
Results
Figure 2. Contact Force (Y) for Node 58171
Figure 3. Deformed State of the Snap Fit Assembly
Figure 4. Element Stress Plot of the Snap Fit Assembly
Model Files
The model file used in this example includes:
<install_directory>/hwsolvers/demos/optistruct/examples/CONSLI_Sliding.fem
