Application Area 1: Path Synthesis
This technique is used primarily with kinematic mechanism models, such as systems with zero degrees of freedom. Typically, one of the inputs links is provided an input motion. The task at hand is to compute the link lengths so that an output point on one of the other links follows a prescribed path.
- Design Objective
- Determine the link lengths of the 4-bar mechanism so that the midpoint of the coupler link traverses the path shown in the image on the right, in red.
- Design Variables
- The locations of points A, B, C and D that determine the link lengths.
