Application Area 8: Cam Hinge Optimization
A cam hinge is used in many appliances (ovens and refrigerators, for example). The function of the cam hinge is to let the door stay at arbitrary position freely during the opening or closing operation. By doing so, it ensures that a minimum amount of force is required to open or close the appliance.
The figure below shows a side-view of a simplified oven. The green door hinges about point O and opens or closes as shown. As the door opens, the bottom surface AB (highlighted in yellow) slides over a pin P.
- Objective
- Modify the cam profile AB so that the torque required to move it from the closed to the open position is minimized. We wish to minimize the torque during the entire range of operation. The cost function is:
- Design Variables
- The cam profile is defined a parametric curve, such as it is parametrically defined as a function of the knots of a B-spline. The knot coefficients are the design variables. Give a set of knot coefficients, a unique, smooth curve can be reproduced. In this example there are 8 knot coefficients. The initial guess for the profile is that it is a straight line.
- Results
- The optimized cam profile is shown in the figure below.
