GET_NCONTACTS
Utility/Data Access SubroutineUsed to extract the number of rigid body contacts during the simulation.
Use
This subroutine can be used to extract the number of active rigid body contacts in MotionSolve
- Fortran Calling Syntax
- CALL GET_NCONTACTS(ID, I_GRA_ID, J_GRA_ID, NCONTACTS, ERRFLG)
- C/C++ Calling Syntax
- c_get_ncontacts(id, i_gra_id, j_gra_id, ncontacts, errflg)
- Python Calling Syntax
- [ncontacts, errflg] = py_get_ncontacts(id, i_gra_id, j_gra_id):
Attributes
- ID
- [integer]
- I_GRA_ID
- [integer]
- J_GRA_ID
- [integer]
Output
- NCONTACTS
- [integer]
- ERRFLG
- [logical]
- The GET_NCONTACTS utility function can only be used within a CONTACTPOST subroutine to retrieve the number of active contacts within the model at the current time step.
- This utility function is often called in conjunction with the GET_CONTACT_POST utility function.
