Use the Sensitivity Analysis and Compare Sensitivity Analysis tabs to compare
sensitivity data across two versions of Radioss/OptiStruct. You can maintain a config file that contains the
parameter(s) to change for the sensitivity study. Based on the config file, a certain number
of decks are generated and solved, and a report is generated comparing the sensitivity
corridor, response curve (Time vs Response), and statistical details.
Click the Solution tab then the Sensitivity
Analysis tab.
Select Radioss or
OptiStruct from the
Solver Type drop-down menu.
Choose between a PowerPoint or
HTML report of the result value comparison.
Select the current solver version.
Load a model file.
Tip: Click Use existing results and select
the Result directory where the results already exist if, applicable.
Load the config file.
Select an output directory.
Click Generate Decks/Run
Solver.
Click Apply yo extract TRC information from the data
file.
Select a subcase from the drop-down menu.
Select an X type from the drop-down menu.
Select any combination of Y Type, Y Request, and Y Component values from the
populated areas.
Click All to select all items listed.
Click Apply to generate a sensitivity report.
The Sensitivity Report section displays the
current file and the corresponding Reference file. Click
Report to display sensitivity corridor, response
curve (Time Vs Response), and statistical details.
