Coupling
Coupling refers to the forces and moments generated in a bushing to oppose the overall deformation of the bushing. These forces and moments are independent of any coordinate system that might be used to measure the deformation or deformation velocity. Coupling is an important factor when the bushing characteristics are non-linear.
Below is information on the formulation for coupling followed by three examples that show how coupling affects bushing force and torque output:
Coupling Formulation
The Altair Bushing Model supports three options for coupling:
- Cylindrical coupling (2-dimensional)
- Spherical coupling (3-dimensional)
- No coupling
Two-dimensional coupling and three-dimensional coupling are analogous, and therefore, this guide explains coupling in terms of the two-dimensional concept.
For cylindrical coupling, assume:
- A bushing has been fitted in two radial directions: x and y.
- The internal states for the bushing are d, the bushing deformation, v, the bushing velocity, and q. These can change with direction.
- Gx(d,v,q) defines the force function in the x-direction, as obtained by the fitting process.
- Gy(d,v,q) defines the force function in the y-direction, as obtained by the fitting process.
- During simulation, at any time t, the bushing undergoes deformations of (x, y) and deformation velocities of (˙x, ˙y) .
The diagram below shows the deformations and force vectors in the bushing. The J Marker is used as the coordinate system for all calculations.
- ˆexj and ˆeyj
- are the unit vectors along the x- and y-axes of the J marker. For cylindrical coupling, axial deformation is uncoupled. Only the x- and y-forces are coupled.
- ˆer
- is a unit vector along the deformation vector.
- r
- is the magnitude of the deformation. Its components along ˆexj and ˆeyj are denoted as x and y respectively.
- ˆen
- is a unit vector orthogonal to the deformation vector. It points to the tangential velocity that may exist in the bushing.
The table below shows the various quantities of interest and how they are calculated:
Quantity | Formula |
Deforming vector | →r=rˆer=xˆexj+yˆeyj |
Unit vector along radial deformation | ˆer=(xr)ˆexj+(xr)ˆeyj |
Unit vector perpendicular to deformation | ˆen=(−yr)ˆexj+(xr)ˆeyj |
Bushing radial deformation | r=√→r·→r=√(x2+y2) |
Bushing tangential deformation | r=→r·ˆen=0 |
Deformation velocity vector | →˙r=˙xˆexj+˙yˆeyj=vrˆer+vnˆen=(x·˙x+y·˙y)rˆer+(x·˙y−y·˙x)rˆen |
Bushing radial deformation velocity | vr=(x·˙x+y·˙y)r |
Bushing tangential deformation velocity | vn=(x·˙y−y·˙x)r |
Bushing force vector | →F=Fxˆexj+Fyˆeyj=Frˆer+Fnˆen |
Radial force | Fr≜xr|xr|Gx(sign(x)·r,vr,qrx)+yr|yr|Gy(sign(y)·r,vr,qry) |
Tangential force | Fn≜yr|yr|Gx(n,vn,qnx)+xr|xr|Gy(r,vn,qny) =yr|yr|Gx(0,vn,qnx)+xr|xr|Gy(0,vn,qny) |
Force in the x-direction | Fx=→F·ˆexj=xrFr−yrFn |
Force in the y-direction | Fy=→F·ˆeyj=yrFr+xrFn |
Coupling Examples
- Example 1: Isotropic Bushing with No Damping and Constant Rotating Deflection
- A constant deflection of 5 units stretching the bushing and rotating at 2*π
radians/sec is imposed on the bushing. Rotation occurs in the X-Y plane of
the J-Marker.
The following equations show the forces Fx and Fy computed by the coupling formulation. The plot shows that Fy vs. Fx is a circle as expected.
Figure 2. - Example 2: Isotropic Bushing with No Damping and Constant Rotating Force
- A constant tensile force of 125 units, rotating at 2*π radians/sec is
imposed on the bushing. The force rotates in the X-Y plane of the
J-Marker.
The following equations show the deformations x and y as computed by the coupling formulation. The plot shows y vs. x is a circle as expected.
Figure 3. - Example 3: Anisotropic Bushing with No Damping and Constant Rotating Force
- A constant tensile force of 125 units, rotating at 2*π radians/sec, is
imposed on the bushing. Rotation occurs in the X-Y plane of the
J-Marker.
The following equations show the deformations of x and y as computed by the coupling formulation. The plot shows that since the bushing is non-isotropic, the y vs. x plot is not a circle, but a smooth, elliptical, closed-curve as expected.
Figure 4.
