An Analysis is a collection of model configuration, analysis loadcase and analysis set-up selections that completely specifies
the assembly definition for a particular loadcase simulation event.
Create panel sets by selecting nodes/elements and/or existing node sets in the model file, that will automatically be
used in setting up Panel Participation diagnostic output in NVH analysis.
Create defined response points that will be automatically used in setting up output
requests in NVH analysis.
From the Analyse ribbon, click the Response tool.
To add response points, click the icon, which opens the Select Tagpoint Metawidget
dialog, and select a module with tagpoints in it. To delete a response point, highlight the
row corresponding to the response point, and then click the icon. When completed, click Update to save
changes made to response points or click Cancel to discard changes
made since the last update, and exit the dialog.
