Panel Set Manager
Create panel sets by selecting nodes/elements and/or existing node sets in the model file, that will automatically be used in setting up Panel Participation diagnostic output in NVH analysis.
From the Analyse ribbon, click the Panels tool.
To add a panel set, click the icon, which opens the Define Panel Set dialog, enter a panel set name in the Panel Set name field and then select a set of grids, components, or elements using the entity selector. When completed, click Create to create the panel set or click Cancel to discard changes made, and exit the dialog.
To edit a panel set, select the row corresponding to the panel set, click the icon, which opens the Define Panel Set dialog, and make appropriate changes. To delete a panel set, highlight the row corresponding to the panel set, and then click the icon. To select panel sets as the active panel sets, highlight the appropriate rows and click Select. Panels can be reviewed by clicking the icon.
Figure 3.
Figure 4.
