Frequency Set Manager
Create standard analysis frequency sets that will be automatically used in setting up analysis frequencies in NVH analysis.
To add frequency sets, click the icon, which opens the Define Frequency Set dialog, enter a name in the Frequency Set name field, select a frequency increment type in the Incr type field, and then enter appropriate values into the Min, Max, and Incr size fields. When completed, click Update to save changes made to frequency sets or click Cancel to discard changes made since the last update, and exit the dialog.
To edit a frequency set, highlight the row corresponding to the frequency set, and then click the icon, which opens the Define Frequency Set dialog, and edit the appropriate fields. To delete a frequency set, highlight the row corresponding to the frequency set, and then click the icon.
To select frequency sets as the active standard frequency set, highlight the appropriate rows and click Select.
