Manufacturing Solutions
HF-3000: Auto Process
Previous topic Next topic Expand/collapse all hidden text
This tutorial teaches you how to use the Auto Process utility to set up and run an incremental stamping analysis with RADIOSS or LS-DYNA.
Prerequisites
Familiarity with basic HyperMesh functionality such as geometry cleanup, meshing and mesh editing. To learn more about these functions, see the HyperMesh help and tutorials.
Files for this Tutorial
forming_autoprocess.hf
hmtoggle_plus1greyOverview of Auto Process
You can access Auto Process from the Tools menu in the Incremental_RADIOSS or Incremental_LS-DYNA user profile.
Note:
You can choose to set up a simulation from either user profile, however you should not switch between the two in the middle of the setup.
To set up an analysis for LS-DYNA, select the LS-DYNA user profile, and then apply the same methodology for the RADIOSS user profile as shown in this tutorial.
The Auto Process tool leads you through two steps of the analysis process, Setup and Detail:
Analysis Process
Setup
Lets you specify an analysis type and the input parameters for your simulation. The blank and tools of the forming process have fields for you to enter values. After entering values, you can select Auto Position to automatically adjust the position of the tools.
An Apply option lets you save the current tool and blank settings, generate load curves, and create input files for the RADIOSS solver. After the Apply operation, you can verify that the tool motion is correctly defined by reviewing animation control.
Detail
Review the setup and make modifications to the input data as necessary.
hmtoggle_plus1greyExercise 1: Set Up the Model for an Incremental Analysis
1.From the File menu, click Open.
2.Navigate to the model file, forming_autoprocess.hf, and click Open.
Note: The model files for this tutorial are located in the file mfs-1.zip in the subdirectory \hf\Incremental\. See Accessing Model Files.
The model loads and looks something like this:
hf-3001-1
1.On the toolbar above the modeling window, click the Single Action Draw autoProcessSad-24 icon.
2.On the error message that displays, click OK.
The Autoprocess panel appears:
autoprocess_setup
Note:
Components are recognized if the names are identical or have common letters to the tool nomenclature in the Auto Process macro such as Blank, Die, Punch and Binder.
The colors of the components are picked up by the schematic of Single Action Draw inside of Auto Process.
Parts that are not recognized appear with dashed lines within the Auto Process image.
1.Check that the Process field is set to Single Action Draw.
2.For Draw beads, select No.
3.For Symmetry/Constraints, select –x (Symmetric to YZ plane).
4.For Draw direction, select –z.
Note: In a Single Action Draw, the die closes in by following the negative Z direction.
5.Verify that the file type is HF in the Source file column for Blank1, Die, Punch and Binder. You have two options: HF and Geometry file. For Blank1 you have an additional option of STATE file.
hf-3001-3b
6.Use the pull down selector img00125 in the Component column and select the components sheet, Top, Punch and Binder as you see in the following image:
hf-3001-4
Notice the components are recognized with a solid line in the Auto Process image.
7.Click the Autoposition button.
8.In the warning dialog that appears, click Proceed, and then do one of the following:
To apply the tool travel values calculated by the utility, click Apply.
To apply values that are user-defined, click Cancel, and then select a tool Name to activate the column headings for that tool. Enter the appropriate values in the travel fields, and then click Apply.
1.Click the space next to the component Blank1. The arrow HF-3001-arrow activates the component and lets you modify parameters for that component.
hf-3001-6
2.Define the material and thickness for the blank:
For Material, select CRDQ steel (default).
For Thickness, enter 1.0 (blank thickness in mm).
Define the other fields as you see in the image above.
3.Click the Autoposition button.
Travel distances are calculated and the respective boxes are populated accordingly.
All tools move to the appropriate location so that they just touch the blank as you see in the following image:
hf-3001-5
Note: In order to use your own values for tool travel and velocity, simply edit the values in the respective boxes, and then click Apply. Do not click Autoposition.
1.Click the space next to Die. The arrow HF-3001-arrow activates the component and enables you modify parameters for that component.
hf-3001-7
Travel 1: The distance the die travels towards the binder (mm).
Velocity 1: The velocity at which the die travels towards the binder. The suggested velocity is 2000 mm/s.
Travel 2: The distance the die travels towards the punch (mm). Enter 70.0.
Velocity 2: The velocity at which the die travels towards the punch. The suggested velocity is 5000 mm/s.
1.Click the space next to Punch. The arrow HF-3001-arrow activates the component and lets you modify parameters for that component.
hf-3001-7a
Clearance: The distance between the punch and the blank at the initial configuration. Keep default setting 0.0.
1.Click the space next to Binder. The arrow HF-3001-arrow activates the component and lets you modify parameters for that component.
hf-3001-7b
Type: The type can be either Force, or Gap:
Force: In this method, a force is applied to keep the binder closed.
Gap: Gap (mm) is defined as the actual physical distance between the binder and die that is maintained after the binder closure until the draw is completed, after subtracting the blank thickness.
2.Select the type as Force, and in the Force field, type 100000.
1.Click the Blank1 field again. Under Material, click fileOpen-24 to open the material database:
HF-3001-08
2.In the steel folder, click CRDQ.
The material data is shown in RADIOSS keyword format along with a curve that corresponds to the stress/strain data. Click Select to make the selection.
Notes:
You can maintain a custom material database. To do so, create the data in RADIOSS keyword format and copy it to
<HyperWorks>\hm\scripts\hyperform\automation\materialdb\materials\steel.
To define a user material library for incremental runs, define the following cards:
/BEGIN, /UNIT, /MAT, /FUNCT and /END
3.(Optional) Use any text editor to open and review the CRDQ material data in the library.
<HyperWorks>\hm\scripts\hyperform\automation\materialdb\materials\steel\CRDQ.rad
#RADIOSS STARTER
## Radioss Input Deck Generated by HyperMesh Version  :
## Generated using HyperMesh-Radioss Template Version :
## Date: 01-30-2009   Time: 17:56:28
/BEGIN
CRDQ.rad
       51         0
/UNIT/MASS/1.0
/UNIT/LENGTH/1.0
/UNIT/TIME/1.0
## Material Law No 43 HILL ORTHOTROPIC (Plasticity defined by a user function)
/MAT/HILL_TAB/1
CRDQ
7.80000000000000E-09
           210000.0                 0.3
                1.6                 1.6                 1.6                 0.0
        1
## Functions
##HWCOLOR curves 1 11
/FUNCT/1
crdq_stress_strain
                0.0               185.0
               0.05          293.188135
                0.1          339.127251
## End Of Radioss Block Deck
/END
4.Click Close to close the dialog.
When Drawbeads is set to yes in the Auto Process, you can launch the Drawbeads Editor using the HF-3001-8a button. The Drawbeads Editor helps you quickly create analytical drawbeads from lines and rapidly manipulate them. You can also edit drawbeads by clicking in the modeling area.
1.To create the Drawbeads row in the table, in the Auto Process panel, next to Drawbeads, select Yes.
hf-3001-8b
2.To launch the Drawbeads Editor tool, click HF-3001-8c.
HF-3001-09
The following tools are available on the Drawbeads Editor toolbar:
Button
Function
hf-3001-db_disp_sel
In the drop-down menu, select Both to display both the drawbeads and lines in the model representation, Drawbeads to display only the drawbeads in the model representation, or Lines to display only the lines in the model representation.
hf-3001-db_createdb
Create a drawbead by clicking points to define the line. When the points are in place, right-click to set the line and create a corresponding drawbead based on the line.
hf-3001-db_adddb
Click to add a drawbead to the table. Then complete the fields for the row in the table to define the drawbead.
hf-3001-db_selectline
Click lines to select them. Lines appear as blue dashes. When they are selected, they become yellow.
hf-3001-db_adddbline
Click to add a drawbead for each line.
hf-3001-db_deldb
Click to delete the active drawbead from the table. The active drawbead in the table has a gray arrow next to it.
hf-3001-db_delalldb
Click to delete all drawbeads.
hf-3001-db_select
Click on a drawbead in the model to select it.
hf-3001-db_movedb
Click a drawbead to select it and then click and drag endpoints to change the size of the drawbead.
hf-3001-db_splitdb
Click a point on a drawbead to split the drawbead into two drawbeads at that location.
hf-3001-db_combinedb
Click two drawbeads when the button is selected to combine them into a single drawbead.
hf-3001-db_undo
Click the button to undo the last action in the Drawbeads Editor. You can also right-click to sequentially remove the most recently created points.
HF-3001-db_mode
In the drop-down menu, select:
Force to set the force calculation mode as the default, which requires that you supply values for restraining and closure forces. You can also use the Drawbead Calculator to determine values.
or
%-lock to set the force calculation mode as percent lock, which applies force as a percentage of the required necking force.
fit-24
Click to fit the model to the current window size.
hf-100-5-17
Zoom feature. Click once to fit the model in the window. Click and drag to draw a rectangle to zoom in on that selection area.
HF-3001-db_pan
Click and drag to move the viewing area when the model is zoomed in.
4.Click the pencil button pencil_icon.
5.Graphically draw a blue line on simplified graphical representation of the model in the top area of the Drawbeads Editor, as shown below.
hf-3001-12
6.After selecting the points, click the create button to complete the first line. Notice the color changes to yellow and the drawbead table displayed.
hf-3001-13
7.Repeat the same steps to create DB2 and DB3, as shown below.
hf-3001-14
hf-3001-15
8.Click the space left of DB1. Notice the corresponding drawbead line changes from green to yellow in the graphics region.
9.Click after the Tstart column in the same row as DB1. This will open the Drawbead Calculator as shown below.
hf-3001-16
10. Accept the current settings and click . Notice all the resultant conditions are calculated for the given geometry, blank material, and thickness.
hf-3001-17
11.Click Back.
Notice that the calculated restraining force and normal force are automatically updated.
12.In the Drawbeads Editor, follow the same steps for DB2 and DB3 to input values for all drawbeads.
13.Click Update to create the force curves for the drawbeads.
14.Click Back to return to the Auto Process setup page.
15.In the Auto Process panel, click Apply.
Note:In the Model Browser, expand the Component folder and locate three components: ^db_line for DB1, ^db_line for DB2 and ^db_line for DB3. These components are generated automatically, and correspond to the three drawbeads.
The Animation Control field makes it possible to verify that the motion is set up correctly. Click the arrow buttons to move forward or back through the process, and observe how the tools move with respect to the blank in the graphics area.
1.From the Auto Process macro module, click  in the animation control field to visualize the tool positions at the termination of the forming stage..
2.Click to get the model position back to initial configuration.
hmtoggle_plus1greyExercise 2: Review the Input Data
1.Click the Details tab.
2.Click the selector and change to All.
hf-3001-18
Note: You can select any option to review.
3.From the Select field, select Die.
You can review the attributes of the die by clicking each item in the tree.
4.In the die attribute tree, review the Velocity Curve as shown in the image below.
5.The curve is displayed on the right hand side and the values are editable. Click the Preview button to preview the new curve after editing and then click on the Apply button to accept the new curve.
hf-3001-19
This picture shows the velocity curve for the die.
6.From the Select field, select Summary.
7.Click Motion Summary.
hf-3001-20
8.Click Force Summary.
hf-3001-21
9.From the Select field, select Control.
10.Click each tree selection and review each topic.
11.Click Animation: Count from the tree selection.
12.Click the selector img00125 next to Animation.
Notice two types of result requests:
Count: Number of result types that are desired.
TFreq: which is displayed at different time intervals until the end of the simulation.
HF-3001-23
hmtoggle_plus1greyExercise 3: Save the File and Run the Analysis
1.To start the analysis, from Auto Process, click Run.
2.When the Save as window appears, save the file name as forming_autoprocess_complete.
Note: This operation writes out a <filename>_0000.rad and <filename>_0001.rad file and launches the RADIOSS solver.
3.From the File menu, click Save As, and save the file as forming_autoprocess_complete.hf.
Return to Incremental_RADIOSS Tutorials
