Manufacturing Solutions
To smooth solid elements
1.Select the solids subpanel.
2.Indicate the elements you want to smooth:
Select the elements on your model.
or
Select elems and choose from the extended entity selection menu.
3.Select iterations = and enter the number of times to apply the algorithm.
4.Click smooth.
Undo
Click reject.
This tool repositions only the interior nodes of the selected elements.
The algorithm used repositions a node to the centroid of the centroids of the attached elements.
