Manufacturing Solutions
To create surfaces by dragging nodes along a vector
1.Select the Surfaces panel, drag along vector subpanel.
2.Set the collector to node list and select the nodes in the correct order.
3.Define the drag direction using the plane/vector collector.
4.Enter the distance value.
If N1/N2/N3 is used to define the drag vector, first set the distance method to determine how the distance is specified.
Or
Use the distance between the already selected N2 and N1 nodes.
5.Click drag + or drag -.
6.To undo, immediately click reject.
