Manufacturing Solutions
To create surfaces by dragging lines along a vector
1.Select the Surfaces panel, drag along vector subpanel.
2.Set the collector to lines and select the relevant lines.
3.Define the drag direction using the plane/vector collector.
4.Optionally, check on or off the merge input lines checkbox.
5.Specify how the new surfaces will be organized by setting the create in option.
6.Enter the distance value.
If N1/N2/N3 is used to define the drag vector, first set the distance method to determine how the distance is specified.
Or
Use the distance between the already selected N2 and N1 nodes.
7.Click drag + or drag -.
8.To undo, immediately click reject.
