1. | Select the create subpanel. |
2. | Click the switch under vector creation method: and select cross product. |
3. | Pick the base node for the new vector. |
4. | Pick the first vector in the cross product. |
5. | Pick the second vector in the cross product. |
6. | Select the magnitude creation value: |
7. | Click the switch by magnitude creation value to select the method you want to use to specify the magnitude of the vector. |
• | If you select user, enter the value of the magnitude. |
• | If you select vector a, the value of vector a is assigned. |
• | If you select vector b, the value of vector b is assigned. |
Undo
Click reject.
This method is dependent on the order of selection for the vectors. Remember A X B != B X A...
