Manufacturing Solutions
To update vectors
To update vectors
To update vectors
1.Select the update subpanel.
2.Indicate the vectors you want to update:
Pick the vectors on the screen
or
Click vectors and choose the vectors from the pop-up menu.
3.Modify the appropriate information in the menu.
4.Click update.
An update menu is displayed.
5.Select the data fields on the vectors that you want to update.
6.Click update.
A two-noded vector that is updated using base and magnitude loses its head node association.
