| 1. | Select the create subpanel. |
| 2. | Click the switch under vector creation method: and select two nodes. |
| 3. | While from node is highlighted, pick the base node of the vector. |
| 4. | While to node is highlighted, pick the head node. |
| 5. | Click create. |
Click reject.
This method creates a vector associated with two nodes. One node serves as the base or tail node, and the other as the head node. The magnitude and direction of this type of vector is updated whenever the two associated nodes are transformed.
