Manufacturing Solutions
Solution Extract Function
The RTM solver enables you to define monitoring points in the flow domain.  The solution at these monitoring points is extracted after every time step.  This solution is printed in the file with the extension .exp.
BEGIN PROBLEMDATA
     ExtractPoint Probe1 { xyz = x  y  z }
END
The *.exp file contains the solution variables  pressure, resin saturation, velocity (u, v, w) and temperature at the extract points.
BEGIN PROBLEMDATA
     ExtractPoint myprobe  xyz = 0.5  0.5  7.5 }
END
