Manufacturing Solutions
Specifying Functions
The RTM solver allows you to input preform properties and boundary conditions as a function of space and time.  This is done using the FUNCTIONS block. The function can be an expression, a one-dimensional table, or a two-dimensional table.
BEGIN FUNCTIONS
     Function_Type   Variable { Expression/Data }
END
Valid entries for Function_Type are: CONSTANT, TABLE1, and EXPRESSION.  The variable is the name of the data field represented as a function.  The expression denotes algebraic expression used to compute the variable.  The data denotes the tabular data used to compute the variable.  Examples of syntax for the function types are provided below.
Example 1: Table 1
BEGIN FUNCTIONS
TABLE1 gate_p { LINEAR
0.0  1.0E+05
0.2  2.0E+05
1.0 3.0E+05
END
BEGIN BOUNDARY
InjectorBC inlet  {
PortLocation    = 0.5 0.5 0.0
Pressure        = gate_p
ResinSaturation = 1.0
END
Here injection pressure is specified in the form TABLE1.
Example 2: Expression
This tcl procedure should be sourced from  the driving tcl file. For example, this procedure is saved in a file called gate_p.tcl.
Contents of gate_p.tcl
proc gate_pressure {t} {
set Time 0.2
set pi2 [expr asin(1.00)]
set MaxP 1.0E+05
set MinP 5.0E+04
set Diff [expr $MaxP - $MinP]
set value [expr $MinP + $Diff*sin($t*$pi2/$Time)]
return $value
Now the driving tcl file should have its first line as
source gate_p.tcl
and in the grf file is
BEGIN FUNCTIONS
EXPRESSION gate_p "{t} { gate_pressure $t }"
END
BEGIN BOUNDARY
   InjectorBC inlet  {
Pressure=gate_p
END
This will make the code use a function for computing injection pressure.
