Manufacturing Solutions
Relative Permability Data
This is used to specify user relative permeability curves. The current user interface does not support this data and it has to be added manually in the GRF file.
BEGIN  PROBLEMDATA
RelPerm  name { Data }
END
Data to be specified
Resin
D_Resin
Air
D_Air
P_Capillary
D_P_Capillary
Derivative
Variable
Default Value
Valid Range
Data Type
Significance
Resin
1.0
0 - 1
Function of S
Relative permeability of resin as a function of S
Air
0.0
0 - 1
Function of S
Relative permeability of air as a function of S
D_Resin
0.0
Bounded number
Function of S
d (Resin)/dS - Derivative of relative permeabiity of Resin
D_Air
0.0
Bounded number
Function of S
d (Resin)/dS - Derivative of relative permeabiity of Air
P_Capillary
0.0
Bounded number
Function of S
Capillary pressure as a function of S
D_P_Capillary
0.0
Bounded number
Function of S
Derivative of Capillary pressure with respect to S
Derivative
1
0/1
Constant
1 - Compute Derivative
0 - Derivative functions given
BEGIN FUNCTIONS
EXPRESSION kr "{swet} { kresin $swet }"
EXPRESSION ka "{swet} { kair $swet }"
EXPRESSION pc "{swet} { pcap $swet }"
END
BEGIN PROBLEMDATA
RelPerm mycurve {
           Resin = kr
           Air = ka
           P_Capillary = pc
END PROBLEMDATA
Corresponding to this data, you have to load the tcl functions in the commands file.
source relpermcurve.tcl
